I noticed we didn't have one of these, and figured I'd make one. I mod on some car forums, and they are usually pretty interesting topics.
So did you mod, maintain, fix something?
Today
- I changed and bled the rear brakes (now its very very stiff hmmm)
- Relocated the rear signal to the shock mounts using a kit (required pulling the shock tops, rear fender, under-fender, cutting the under fender, and extending the wires)
- Installed the side-mount from Killervrod.... had to cut my plate smaller, but looks good. I didn't install the LED yet.
- Removed the Screaming Chicken exhaust and packed them up, getting TAB's this week
Started and rode today. The Battery Tender solar panel really works. Battery was dead a couple of weeks ago. Plugged the Sola panel in and today it popped right off. Charging my truck with it right now.
Started disassembly to get the engine removed. Got some more new parts on order and found the rims I want to install. Got this far and decided to build a bench with some underside shelving to put parts on.
"R" got new tires.
It was Avon Cobra Chrome, a tire I can recommend. Never any unpleasant experiences either on dry or wet roads. Would have liked a little longer life on the rear wheel, the front wheel still had 50% tread left, mostly touring, no weekend warrior. Had the opportunity to check the swing arm bushings, brake pads, wheel bearings and belt & pulley. A quick polish of the rims was also on the check list. Christmas came early, everything OK. Now it is Bridgestone that is fitted front and rear, have not tried that brand before but should have received good reviews.
Adjusting the drive belt to the correct tension is one thing, getting the wheels aligned is another. Can be a painstaking process that should not be underestimated. Ron B. has commented on this several times and it is the case that the solution H-D uses to adjust the wheel axle is marginally usable. That patent was used in this country in the 50s and 60s on Ă–gland/Sachs 50cc mopeds...
A new Avon 180-18 has been ordered so I can wear out the front tire too...
Yes, I've vented on here extensively as well in regards to the snail cam adjuster " system ". Absolute junk if you really watch what you're doing when you tighten down the axle. Play in the slotted snail cam is biggest problem, it needs to be rotated on the axle to the proper matching position as the welded on snail adjuster then the slot needs to be welded so there is no play when slid on the flats of the axle. Since my wheel is all the way forward to reduce the wheelbase ( using 30t fwd pulley with 28t belt ) I've dreamed of creating shim blocks to go in the swingarm slots fwd of the axle to hold it in place so you could tighten it down lightly and tap the axle fwd to remove play then final tighten. Bolt with locknut style pull adjusters could be retrofit but the axle spacers would have to be narrowed for them to fit, and lands machined into end of swingarm for bolt to locate and rotate on. Big PIA for correcting a lousy H-D OEM setup. I just drink another beer or two and spend an hour torturing myself getting the loosey goosey setup tightened down in alignment.
I sourced a powder coater who will work with the airbrush artist I chose on matching the colors for my winter project.
Related Threads
Harley Davidson V-Rod Forum
2.7M posts
68.6K members
Since 2003
