rear axle removal on 2007 vrsaw 240 tire - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > Specific Model > VRSCA , VRSCAW
Reply
Thread Tools Display Modes
Old 05-15-2017, 06:41 PM   #1
bikerwoman
Registered Full
Feedback Score: 0 reviews
Unhappy rear axle removal on 2007 vrsaw 240 tire
Hi Vrod friends,
I'm currently trying to take my back wheel off my bike to take down and get a new tire put on but am having problems removing the axle from the wheel hub. I managed to get the nut off the right side and the axle isn't coming out when I have tried pulling it with a pair of channel locks. Do I need to remove exhaust to tap on axle with a rubber mallet? I'm at my wits end and have broke off 3 fake nails in the process! Could someone please help me with some instructions?
Thanks for any info
If anyone has any concerns as to whether or not if I know how to work on bikes, I do some things and am very mechanically inclined...I also have a 2002 Harley Softtail that I work on and I also work on my own cars. One of which is a 1968 Dodge Coronet with a big block.
bikerwoman is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-16-2017, 07:53 AM   #2
mikeinatlanta
The Massive Pr1ck
mikeinatlanta's Avatar
Happens on occasion when some jack wagon over cleans the axle and fails to lube it before installing. Just a tiny bit of corrosion will keep it from sliding through the bearings and spacers. Unfortunately the only trick is to put the bike on a nice stable stand, remove what you need to, and be careful to not do damage as you beat the crap out of it. You can't even pull the entire assembly and take it to a machine shop without cutting a very expensive belt. There is no good answer, but I have a special brass ended drift that attaches to my rivet gun for such situations. The sharp impact of the rivet gun does less damage than a heavy hammer.
mikeinatlanta is offline   Reply With Quote
Old 05-16-2017, 10:06 AM   #3
rbabos
Registered Full
Get a high quality real penetrating lube, not WD40 which is good for shit. Spray it up good and work the axle both ways with hammer and soft drift (alum or bronze) until the penatrant slowly breaks down the rust on the axle. Remember, if water or moisture got in there to rust it in the first place, the oil will eventually get in there too. Time and patience.
rbabos is offline   Reply With Quote
Old 05-16-2017, 05:35 PM   #4
bikerwoman
Registered Full
Thanks, guys, I was able to finally get it off after taking a hammer and pound on it....it's not rusty at all.....just a really tight fit.
Old 05-16-2017, 07:36 PM   #5
rc4man
EXCELSIOR
rc4man's Avatar
Feedback Score: 4 reviews
Clean it good and spray it with lithium spray grease before reinsertion.
You can get it at any auto parts shop.
"V" Rod Forman, '04 Anodized "B", 50th B-day gift from wife.
rc4man is offline   Reply With Quote
Old 05-16-2017, 07:41 PM   #6
bikerwoman
Registered Full
thank you for the info....will do. I also was told to use marine grade grease. any thoughts on that?
Old 05-16-2017, 09:21 PM   #7
mikeinatlanta
The Massive Pr1ck
I'd use the waterproof grease.
Old 05-18-2017, 11:47 AM   #8
andy b
Registered Full
no!!! anti-seize! that is the proper thing to brush on the axle
andy b is offline   Reply With Quote
Old 05-18-2017, 12:42 PM   #9
knight rod rob
Registered Full
knight rod rob's Avatar
Quote:
knight rod rob is offline   Reply With Quote
Old 05-18-2017, 05:38 PM   #10
mikeinatlanta
The Massive Pr1ck
Negative on the anti-seize. General corrosion protection and stopping galling are two very different things. While anit-seize may provide corrosion protection, that is not its intended use. You're just throwing away money.
Old 05-18-2017, 08:17 PM   #11
biker bob
Registered Full
biker bob's Avatar
Feedback Score: 2 reviews
you guy's should have known a woman with a hammer and a little up set can take care of any of her problem's .
biker bob is offline   Reply With Quote
Old 05-19-2017, 08:07 AM   #12
rbabos
Registered Full
In reality any form of grease is fine. Anti-seize will work but it's not needed as it's not really what it was designed for. Actually while we will not see this on our bikes, certain types, depending on whether copper based or aluminum based can actually cause corrosion to certain metals in the right conditions. Not cut and dried as one would think. Waterproof grease is probably a better choice. Let's face it, anything is better then what the factory used, which is nothing.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
