So I have been checking out heaps of the threads on here and doing a little research on a turbo for my 2010 muscle. I want to build something similar to the Trask kit available and would appreciate any help I can get with it. I only just decided last couple days to actually attempt it as I got hold of a fabricator who is willing to make me a plenum, manifold and exhaust!!
This wont be an overnight project as the bike is allready stripped for paint/powdercoating but hoping to have it finished over the next 2-3 months. Reason I am not going a ready made kit is.. well $$$$$..
*Im going to go with a garrett gt2554r or possibly gt2860r
*Im planning to get a v-band connector for the outlet to suit a 3" exhaust.
*making exhaust connect to a silencer mounted to the stock muffler mound.
Anyhow, the first query I have is about the plenum. I put a pic up of what I think is a Trask plenum and circled/lettered the hose connections on the plenum and would like to know were they each go. Also I read that a 'v' channel is used inside the plenum to regulate air flow... Is that right?
a pressure hose to Boost Gauge and Fuel Regulator
b breather hose / feed to air intake filter or seperate catch filter.
c front case breather hose
d rear case breather hose
Square welded onto Cyinder is a oil catch from the cases and self drain back through the same hose.
The 'v channel' is just a length of angle welded in the plenum. If you are designing your own system consider reading up on plenum design. Lots of good information available.
That is the angle I was talking about. Due to the charge inlet position at the rear this angle is used to keep the rear cylinder from being 'overloaded'. Design a plenum with more even distribution and you can eliminate this obstruction.
Actually, the overloading will be the front cylinder, the air will blow right over the rear cylinder and starve it, and put all the air into the front cylinder.
With the limited space you have to work with, you are going to be hard pressed to make a more simplistic yet effective (cost and performace) plenum than this design. This is definitely one time and place the KISS method is probably the best way.
So I am meeting with my fab guy this weekend. Seems 2-3 months might be 3-4weeks..
Have the option of 2 turbos he has
1. GT2554R
2.GT2560R
Suggestions???
What about tuners???
So I take it I need the 2map bar sensor? (trask)
Do I use this with the thundermax auto tune??
Or pc5?
My bike has a SE Pro Super Tuner on currently
32109-08A 08/15/09 dated
Does this have to be cleared to stock prior to supertuner install??
I hear you can use just the SE tuner?? Would I still need the 2 bar map sensor? Do I need a an independent wide band sensor with it? Does anyone have Amap for use with the se tuner to suit the gt2554r 8psi mod?
Sorry for all the questions and thanks in advance!!!!
Are you doing the fab work your self? If so, are you buying pre bent pieces of exhaust tubing and piecing them together or are doing the work on a tube bender?
I have a used Trask plenum. The BOV treads are stirpped but could be easily modded by your guy. Why re-invent the wheel? The new plenum from Trask was $500.
I'll ship you this one for €200 with BOV. (I'm in Germany so should be no prob in the EU)
Internal wastegate on gt2554r (Yes it will be tight in there)
I have a mechanical engineer fabricating the kit up. Once finished and tested on my bike will produce more the same.
Im interested in the plenum definetly.
Turner software and cables arrived!!!!! Also hooked myself up with a Barnett clutch kit!!
Hopefully have some pics of the completed manifold and attached turbo on the weekend.
Anyone know how to upload files to the se program. Eg mt6 file?
I have nothing against the Barnett clutch, but I would have suggested to get the slipper instead.
Related Threads
Harley Davidson V-Rod Forum
2.7M posts
68.6K members
Since 2003
