I noticed we didn't have one of these, and figured I'd make one. I mod on some car forums, and they are usually pretty interesting topics.
So did you mod, maintain, fix something?
Today
- I changed and bled the rear brakes (now its very very stiff hmmm)
- Relocated the rear signal to the shock mounts using a kit (required pulling the shock tops, rear fender, under-fender, cutting the under fender, and extending the wires)
- Installed the side-mount from Killervrod.... had to cut my plate smaller, but looks good. I didn't install the LED yet.
- Removed the Screaming Chicken exhaust and packed them up, getting TAB's this week
Thumbs up on the Metz. Two thumbs up on the Daymaker. I swapped out the headlamp on the Softail to the Daymaker earlier this week. No more dirty brown light. I'll stick with the HID's on the DX.
I'm planning to pull the can off my V&H 2:! Comp pipes tonight and repack the baffle. I disassembled the pipes late last summer, and it was nearly impossible to re-assemble without losing half the packing. Hopefully, that will happen tonight.
Slept in and thought I would take a late ride out to Daytona. For the first time since I have owned it, my bike would not start. The battery was toast. So today what I did to my vrod was replaced the battery. I can't complain, it's lasted for over 8 years.
I tried to melt the snow outside with brain powers to hasten the coming of spring. Also, I read the instructions for installing my new sundowner seat. Again. Go away, winter!
Haven't ridden the bike since my accident in October. Got her all back together and it was finally above 40 degrees, so I took her for a ride. It's been too long.
Thanks, man.
I bought some $12 boots that I thought I could cut up and paste back together.
They didn't work out that way (too tight at top), so this was a 30 minute test to see if I want to go through the process of taking off the front wheel to do that. I think I do. Here's the ones that I got: http://www.summitracing.com/parts/EXP-12127
I cut the top 5 inches off.
2 seasons ago I wanted to experiment and see how my bike would look with fork boots. I went to the dealer and grabbed a set of 39mm Sportster gators that were in stock, cut them down the back with scissors, and zip tied them on. Looked pretty good and you could only see the slit from the rear and you really had to look for it. Finally at the end of last season they actually started to tear because they weren't compressing the way they are supposed to I guess. I just got in a set of proper 49mm boots for when I service my front end soon...
Related Threads
Harley Davidson V-Rod Forum
2.7M posts
68.6K members
Since 2003
