Sprintex Supercharger - Page 4 - 1130cc.com: The #1 Harley Davidson V-Rod Forum
Old 12-10-2012, 06:51 PM   #46
Watching this one. 2013 should be a good year for boost!
Old 12-10-2012, 07:48 PM   #47
joe,
I am hoping Sprintex steps up to the plate and answers my Questions.
I called them tonight and left message!!!!!
Old 12-10-2012, 11:56 PM   #48
Hope u left questions at the USA dept .the Australian one is as slack as shit getting back to you.on anything.freaking western Australians .getter
Old 12-11-2012, 07:04 AM   #49
VrodPete
Elephant Motors Rock
VrodPete's Avatar
Originally Posted by rsc View Post
Pete, I think I would leave it alone and enjoy that 1402.
Wait till something is proven.
Still waiting to hear for AU...
Rod
I have no plans to be a beta tester! Once I see which SC is showing reliability, I think I know what needs to be done in order to build a motor that won't come apart or seize as long as boost is kept within some reasonable limits and there's plenty of fuel to keep things cool.
'08 VRSCAW
1402 Oilman Elephant Motor - Fitzgerald Motorsports Style
(Fourteen-Oh-Twous Copicaticus)
HD SE II Cams, 3/8" Falicon Crank, Carillo Rods, CP Pistons, DA Fitz Engine Brace, Destroyer Injectors, Doherty oil pan, DA Fitz Head Port/Polish/+1mm Valves+springs, DA Fitz 58mm TBs, ARP studs, V&H 2nd Gear+Shift Shaft, Motohouligan Airbox, Wegner 2->1 Exhaust with Supertrapp V5
152.77 HP, 101.06 TQ
Other Toys: '01 BMW K1200LT, '76 Honda CB550F, '81 Mooney M20J
VrodPete is offline   Reply With Quote
Old 12-11-2012, 11:57 AM   #50
Consig64
FATASSDX
Consig64's Avatar
Images: 33
Originally Posted by VrodPete View Post
I'm tossing this idea around, just not sure which SC I'd want to put on just yet...
Yes, this will be on a 1402 motor, but I have some other plans for it to help keep it together. I'd have to change the cams, probably re-work the heads (again - long story there aye Scott?), move to a higher flow fuel pump, look at the fuel rail capacity, and change to a 30 tooth pulley along with a stronger clutch, and possibly the Trask output shaft side brace (if they are even making them???).
I would probably also start conservative with the boost and try to find a happy "180HP+" spot to settle into...
I'm already frying a 250 tire without much effort, I'm just thinking this could expand the "fun zone" a little more... Heh.
Overall, the project sounds pretty simple
I think you should definitely go for it If it holds together for a few thousand miles I will be right behind you....
08 DX - 1402 Stroker (3/8" Falicon Full Circle Crank, K1 Rods, CP Pistons, 10mm ARP Studs, HD SE II Cams, Destroyer Injectors, V&H 2nd Gear+Shift Shaft, Motohooligan Airbox, Trask Output Shaft Support, Fitzgerald: Head Port/Polish/+1mm Valves+Springs, 58mm TBs, Engine Brace, Billet Chrome Oil Pan, 26t Pulley)
Consig64 is offline   Reply With Quote
Old 12-11-2012, 04:48 PM   #51
Update:
Just spoke to my contact and was informed they where out of country.
A new e-mail was sent. Thanks to my contact for taking the time and going the extra mile to help us here on the forum.
To all of you that are interested and the ones that pm me.
This tread is being watched by them.
So then, If you have any question or questions ask.
Post up so they they can see.
1 New stock or old stock
2 Bearing new style or old style
3 What are the differences
4 What was done to get the new style into unit.
5 How much heat is produced
6 Updates with ecm set up
7 Warranty, what is covered and what is not This is the big one.
8 How long is ithe warranty
9 Are the install instruction updated
10 Anything we should know that has been changed
rod
Old 12-11-2012, 04:54 PM   #52
Please keep this a clean thread.
Old 12-11-2012, 06:13 PM   #53
I11. What cams would work best ..close lap or large like stage 2s.
12. Will it run with a Daytona twin tech tuner with auto tune.
13 would 58 tbs be able to be used or just stock 53s
Old 12-11-2012, 10:42 PM   #54
BIG POPPA 66
Cool
whats the best tuner to use if not supplied with unit?
do they have a base map? i think they should have this isnt new..
hope all that you are going through to get this SC going works out for everyone thanks for doing the the grunt work.
Old 12-12-2012, 04:54 AM   #55
11. Close overlap just like the turbos
13. Look at the link provided. No TB's. You have to put your TB parts onto the the S/C.
Old 12-12-2012, 06:03 AM   #56
so then the answer would be ,stock 53 butterflys ,lol,,but damn on the cams ,i was sure on sc engines big cams were good ,
Old 12-12-2012, 06:08 AM   #57
With S/C it is important to get the heat out!!!!!
Old 12-12-2012, 09:07 AM   #58
ohioVROD
Senior Member
ohioVROD's Avatar
Images: 107
Feedback Score: 31 reviews
Slow and steady is my only recommendation this needs to be done correctly the first time not the third. Building a bullet proof motor is key which will include head work, heat coatings, and engine bracing. I am interested in working with Rod to insure these items are addressed to insure longevity.
D.A. FITZGERALD CO., INC. / FITZGERALD MOTORSPORTS Your one stop performance VRod shop!
Authorized dealer for Vance & Hines, MegaCycle Cams, CP Pistons, Brown's Plating, Carrilo Rods, ARP Studs, Falicon Crankshafts and Diamond Heads.
Services offered: Case Boring-26T Pulley-58mm Throttle Body-Slotting Sprockets-Pinning of Bearings-Custom Machined Wheels & Rear Pulleys- Engine Brace Kit
Contact us at
ohioVROD is offline   Reply With Quote
Old 12-12-2012, 10:20 AM   #59
5aint
5aint's Avatar
if we can figure out the equation to in 170ish at the wheel and like scott said it's still be bullet proof, i'm in.
Current: Kreater carbon kit, BSTs w/ ceramic wheel bearing, Swan composite rotors, K&N Topless, Bub 7 2-1, Daytona Twin Tec, Progressive 440's, MS Biketec upper fork covers, Arlen Ness Deep Cut grips and pegs (powder coated), Arlen Ness RAD III mirrors, HD reduced reach handlebars, Figure custom derby and clutch cover, HD Black LED headlamp, Porsche horn cover.
Ordered:
Planned:Holy-Moto SC, Bitchin Seat
For Sale:PC V (08 retro fit), Sundowner seat
Go big or go home
5aint is offline   Reply With Quote
Old 12-12-2012, 11:32 AM   #60
It all depends on how far ppl are willing to go for bullet proofing? 170-180hp I don't see much of a problem at all especially if your willing to do a teardown and ceramic coat everything possible along with pistons for boosted application.
A Dog will look down when they have done wrong, But a Snake WILL look you in the eyes.
