1487cc Turbo 2nd Edition - Page 16 - 1130cc.com: The #1 Harley Davidson V-Rod Forum
Old 11-18-2012, 12:02 PM   #226
Originally Posted by VrodG View Post
is the GT2560R a direct bolt on or will you make to make changes for clearance?
It is a direct bolt.
I will make some changes to my home made kit. For example the first curve of a charge pipe has been unnessary tight (possible turbulent air flow).
Karzza is online now   Reply With Quote
Old 11-18-2012, 12:29 PM   #227
I was wondering if this would be a bolt on for the trask systems.
did you get the -4 turbo?
Old 11-18-2012, 12:40 PM   #228
Did I get what??
GT2554R is the best choise for 1130...1250cc
Old 11-18-2012, 01:28 PM   #229
Originally Posted by Karzza View Post
Did I get what??
GT2554R is the best choice for 1130...1250cc
Garrett makes a 466541-1 and 466541-4 I was wonder which one you bought?
I have the makings for a 1402 thats why I was wondering if the 2560r was a direct bolt on.
Old 11-18-2012, 01:55 PM   #230
466541-4
I will use my current chromed 2554 turbine housing and
modificate 2560 compressor housing for hoses (inlet/outlet) plus chrome it.
I think GT2560R flange type air filter fitting is even better for Trask setup.
Old 11-24-2012, 08:20 AM   #231
Here are the parts you need to update GT2554R (270hp) to GT2560R (330hp). It is cheaper to buy a complete turbo than a CHRA and a compressor housing separately.
Old 11-25-2012, 12:05 PM   #232
Okay, GT2560R is NOT a direct bolt on in case of Trask. In Nissan 200 it is.
The charge tube's flange bolt pattern is sliggtly rotated. Wery nice done from Garrett.
Compressor housing's horizontal outside diameter is 1" wider.
CHRA is identical, except the compressor wheel diemeter of course.
Old 11-25-2012, 01:02 PM   #233
Cutting the flange off the charge tube to fit the housing isn't a big problem, but the housing being an 1" bigger in dia. might be
Thanks for the pics and info
Old 12-09-2012, 04:44 AM   #234
I decided to machine flanges off from the compressor housing.
It is cleaner way to fit an air filter straight to the compressor.
A linear flow of the first angle of a charge tube is important.
I thing I can build the most streamlined start by a 45 deg silicone hose. Let’s see, if there is enought room.
Some finishing is still needed before chroming.
Old 12-10-2012, 01:51 AM   #235
first class karza looks great
Old 01-04-2013, 10:52 AM   #236
Finally a new compressor is ready for chroming.
A prework was as unpleasant 15 hours manual job as I thought, never again.
Old 01-12-2013, 12:39 PM   #237
The new CHRA and compressor housing are ready to install.
Got also (8deg raked) tripple trees and steering dampers fittings from chroming. The damper will be polished only.
Will visit member Mukle tomorrow to finalize the plenum and breather box.
Old 01-13-2013, 09:22 AM   #238
Hei Karzza.
Great looking!
Will You do any upgrades on the clutch?
Knut.
Knut J is online now   Reply With Quote
Old 01-13-2013, 09:28 AM   #239
Thanks Knut,
I thing no more can do while using a stock right side engine cover.
At the moment the clutch doesn't slip, but it is terrible to use bicause of "biting".
Old 01-13-2013, 09:45 AM   #240
Hei.
I see. So maybe this in the future? http://www.mtceng.com/home/mtc-engin...e-v-rod-slider
Knut
