Blowin fuses - 1130cc.com: The #1 Harley Davidson V-Rod Forum
Old 12-03-2012, 11:13 PM   #1
Shoe
aka shudude
Shoe's Avatar
Blowin fuses
I keep blowin the accessories fuse. If I ride in the rain or wash the bike, the bike will start poppin he accessories fuse (usually the next day). The problem is, when the fuse goes, I lose my brake light and turn signals (that's a serious problem). I can usually tell when it's going to short out, because the turn signal (usually) gets stuck and wont shut off, when it finally shuts off, pop, no signal or brake light. Any ideas?
2003 silver/black, Race Tuner, Topless, CFR Exhaust, Ricks's Tank, Slipper Clutch, Progressive Fork Springs,
Progressive 440 HD Shocks, Memphis Shades Windshield, Corbin Hard bags, Mustang Tour Seat, Reduced Reach Bars, 8000k HID Light, HD LED Tail Light
2012 BMW K1600GTL Midnight Blue
I hate being BIPOLAR
It's AWESOME!
Shoe is offline   Reply With Quote
Old 12-03-2012, 11:49 PM   #2
HoneyB
Pat (Patrick!)
HoneyB's Avatar
Images: 14
Feedback Score: 31 reviews
Water getting into your Handlebar switches? I would cover them with plastic next time, and see if that eliminates the problem.
'04 VRSCB, SERF, Amsoil air filter & oil, Drilled Exhaust, Arlen Ness Mirrors, relocated Signals, Sundowner seat,
Tiger Racing belt guards, Pondo's pivot bolt covers & 'V' valve stem caps, Tyson's black riser and foot levers, Metzler ME 880's, black 5 spoke '08D wheels and rear pulley, Mini LED rear signals, Progressive suspension, Jeannie Guardian Bell!(so far!)
1978 Honda XL350 (w/4300 miles on it!)
Jedi:"It's free to be a member, but it'll cost your ass in the end..."
HoneyB is offline   Reply With Quote
Old 12-04-2012, 12:40 AM   #3
AOW
K.I.A. '07 AW
AOW's Avatar
Images: 85
and dielectric grease all of it to add a layer of water protection...
SERVICE MANUAL!
embrace the "google search" function.... site:1130cc.com:
Originally Posted by rjrivero
Nobody cares about your shit like you
Fuel gauge? We don't need no stinking Fuel gauge!!!
AOW is offline   Reply With Quote
Old 12-04-2012, 05:16 AM   #4
Vambo
Vambo's Avatar
Feedback Score: 21 reviews
Something is exposed that should not be or wasn't when built. You need to go thru all the wiring to find out where. A clue is that it's probably an area that is holding water like the interior of a switch housing or interior of the speedo, or a plug right-side up that is filling with water.
Any changes lately? Mods?
Vambo is offline   Reply With Quote
Old 12-04-2012, 06:03 AM   #5
wianb
Still riding!
wianb's Avatar
Spray all fuzes, switches etc with ACF50. In fact, cover the entire bike with it especially if you ride during the winter...brilliant stuff!!
Royal British Legion Rider
Ian
I was a soldier once, and young.
2011 VRSCDX
Black Denim - V&H Comp Series 2into 1 - V&H Fuelpak - K&N Hi flow filter
wianb is offline   Reply With Quote
Old 12-04-2012, 08:44 AM   #6
Shoe
aka shudude
Shoe's Avatar
No recent mods. I have a biketronic run/turn/brake module, but I checked that and no problems there. I'll check the switches first and go from there.
It's AWESOME!
Old 12-04-2012, 08:27 PM   #7
pScyko
Jarhead
pScyko's Avatar
The systems you lose are where the problem is. The water is causing their supply voltage to take a shortcut to ground. You need to find out where the exposed source wire (s) is and take steps to protect it. Could be multiple things.
/Respectfully Submitted,
Vintage 2002 Harley Davidson V-Twin_Racing_Street_Custom_A_Model_V-ROD
De-badged vivid black & chrome
Weld Racing Charger5 wheels w/ matching pulley
Stage II Cams
Slipper Clutch
Semi-topless SE Modded
16Ga Screamin EagleŽ headers
Screamin EagleŽ Race Tuner (.MT6)
Shorai Li-Fe LFX21
Unlimited Engineering 5.3 Gal gas tank
pScyko is offline   Reply With Quote
Old 12-04-2012, 08:30 PM   #8
pScyko
Jarhead
pScyko's Avatar
Are those kuryakyn relos on your ride? Their wires suck. They do not age well. Mine freyed at the points where they were ziptied and shorted to ground on me. Could be one of your problems.
Stage II Cams
Slipper Clutch
Shorai Li-Fe LFX21
Old 12-05-2012, 04:24 AM   #9
Vambo
Vambo's Avatar
everything kuryakyn sucks............
Old 12-05-2012, 02:39 PM   #10
Rich Moran
Riding the good life
Rich Moran's Avatar
Images: 191
switches are all sealed so with these either they will work or not if OEM part. Had the same issue, I went up to the next fuse by 5 and then 10 AMPS which seems to have stopped the issue. You can go up 10 AMPS more if need be but I would not go further than that.
If you keep on burining fuses after that, treating the contacts with a good electronic cleaner that not only cleans but protects the fuse holder is recommended.
I had used a VpCI (vapor phase corrosion inhibiotr) blue bag for the fuse housing assembly. Slip the fuse holder into the bag, use of electric tape to seal the bag around the harness and then slide the bag onto the tabs where the fuse housing rests. The tabs will poke holes in the bag, but these are not big enough to allow water to accumulate to the point where the bag would fill, at least this was the case with my experience.
Member Number 433 or there abouts...original old timer
Rich Moran is offline   Reply With Quote
Old 12-05-2012, 02:44 PM   #11
gritgolfer
It's Only Money
gritgolfer's Avatar
Never buying anything from those guys again. Crumbiest chrome quality ever!
05 B Racing Orange
gritgolfer is offline   Reply With Quote
Old 12-05-2012, 04:12 PM   #12
pScyko
Jarhead
pScyko's Avatar
Stage II Cams
Slipper Clutch
Shorai Li-Fe LFX21
Old 12-05-2012, 04:27 PM   #13
Shoe
aka shudude
Shoe's Avatar
Light housings are stock. I only use the Kuyakyn clamp to attach to the forks. I used dielectric grease on the lights and connectors, and it still pops the accessory fuse after a about a half hour of riding. Weird thing is, it doesnt blow while riding in the rain, always about a day later.
It's AWESOME!
Old 12-05-2012, 05:48 PM   #14
LL Cool K
Insane inda membrane
LL Cool K's Avatar
Images: 161
Time to move to Seattle... problem solved.
If you see da Police
Warn A Brother!
In loving memory of Betty Boost! 1929-1996
Winner of the 2012 Midwest Thunder7 Johnny Hotfoot Award... Best Rat Bike!
LL Cool K is offline   Reply With Quote
Old 12-05-2012, 06:03 PM   #15
Shoe
aka shudude
Shoe's Avatar
not helpful......
It's AWESOME!
