1250cc heads. How much more can they flow - Page 2 - 1130cc.com: The #1 Harley Davidson V-Rod Forum
Old 11-28-2012, 03:03 PM   #16
vrunner79
vrunner79's Avatar
What about a Destroyer crank. I seen a post somewere were someone posted the difference from a stock 1250 crank to a Destroyer crank. It was slightly longer. Obviously I would have to take the engine apart but to have a stroker engine would be nice
2009 VRSCF
vrunner79 is offline   Reply With Quote
Old 11-28-2012, 03:22 PM   #17
Demthios
To boost or not??
Demthios's Avatar
Images: 19
Destroyer cranks are pretty hard to get a hold of the last time I looked around. Would probably be easy to pick on up from Falicon.
Old 11-28-2012, 03:29 PM   #18
vrunner79
vrunner79's Avatar
I might have a source for one, Question is would it fit? Bearing size,case size etc. What's different from the Destroyer cranks to the factory
2009 VRSCF
Old 11-28-2012, 05:51 PM   #19
rippie74
1130cc is enuff 4 me
rippie74's Avatar
Originally Posted by FABSTER View Post
Those oversized TBs from Vreelands are for track only anf for their equally obscene BB motors (LOL) not for the street!
Yes. When I asked about installing 58's, Ray told me that 53's flow plenty of air, on both the 1130-1250cc motors. 58's are for all out drag racing, sure you could use them on our "street driven bikes". However the Co$t vs. HP gains don't add up. That's why I kept my 53's.
2003 100th Anniversary V_Twin_Racing_Street_Custom_A_Model_V-ROD
Iceberg Blue 8K H.I.D. Conversion
Progressive Suspension
Sundowner
Fender Base Plate/Low Sissy Bar/Luggage Rack
UE Trick Tank
Keyless Ignition Upgrade
Slipper Clutch
Drilled Belt Guards
Superchicken covers
100th Anniv. Windshield
Topless
SE2 Cams
Chromex Coated CFR
Amsoil
Metzeler
Screamin Eagle Race Tuner
rippie74 is offline   Reply With Quote
Old 11-28-2012, 07:35 PM   #20
vrunner79
vrunner79's Avatar
I have a guy that does head work. BUT if I can get away with a stroker engine then all the better. I found a old post on CC/Stroke differences
Stock stroke = 72mm
Destroyer stroke = 75mm
1250 with Destroyer Crank = 1298.9cc
I MIGHT be lucky that a friend MIGHT have a Destroyer crank on hand. Only thing I wonder is will it work with factory parts and will it raise the compression too high were it would need race fuel? I believe the compression on a stock 1250 is 12:0:1
2009 VRSCF
Old 11-28-2012, 08:34 PM   #21
Stock stroke = 72mm
You would also need to install longer rods. Stock rod length is 5.708inches. Destroyer rods are 5.588 inches. A set of Dyer rods runs about 500 dollars (plus bearings).
Old 11-28-2012, 08:42 PM   #22
1130,1250 and destroyers use the same connection rod.
Old 11-28-2012, 08:59 PM   #23
Demthios
To boost or not??
Demthios's Avatar
Images: 19
VrodG is correct, all three use the same rods.
Old 11-28-2012, 09:17 PM   #24
vrunner79
vrunner79's Avatar
SO.. a Destroyer crank should be a direct drop in? Unless the Journal size is different.
2009 VRSCF
Old 11-28-2012, 09:23 PM   #25
Damn, I must have misunderstood K1 when I was talking to them about it.
Edit: Checked my email, was refrencing the Falicon crank, not the destroyer crank sorry.
Old 11-28-2012, 09:24 PM   #26
Demthios
To boost or not??
Demthios's Avatar
Images: 19
Look around others have used the destroyer crank in there stroker projects. Fits the stock cases just fine, more goes in the just that, do some searching.
Old 11-28-2012, 09:35 PM   #27
Wouldnt a 1/4 weld up crank be better than the destroyer crank? Easier to get, about the same money, stronger.
Old 11-28-2012, 10:26 PM   #28
vrunner79
vrunner79's Avatar
I've searched for Stroker engine posts. Most I see are people doing it to the 1130cc engines or just full on Big Bore packages. I have someone very close to me (family) that was involved in the devlopment of the Destroyer before he retired from HD. i'm trying to do my own research before he will work on the project
2009 VRSCF
Old 11-29-2012, 02:17 AM   #29
Stock stroke = 72mm
Those 48cc would be like a $5k job and give you like 7 hp? If you're doimg it gonall the way with the BB IMHO
Old 11-29-2012, 06:53 AM   #30
I agree with Fabio, really not worth spending the money and splitting the case just to swap cranks. Go bb and stroke at the same time... save you alot of $$ in the long run.
