Plenums - Page 14 - 1130cc.com: The #1 Harley Davidson V-Rod Forum
Old 11-16-2012, 09:25 AM   #196
If I remember correctly, Trask used a 2.25 ID x 2.5 OD tube. For 60mm you'd need a 2.375 ID tube. You'd probably need to get a 2.75 OD thick wall piece & bore it out. I'm using the 2.25 x 2.5 on my project. Karzza, can you share a part number / application on the IAC, please ? THX
Old 11-16-2012, 01:22 PM   #197
It is a 20€ racing item.
http://kms.vankronenburg.nl/products...ure-sensors-2/
I have several of them and can sent together with the flange.
Karzza is online now   Reply With Quote
Old 11-16-2012, 01:50 PM   #198
mukle
Originally Posted by Jan-Dirk View Post
what diameter do the two "venturis" have? Would this fit 60mm throttle bodies?
Now 56/62mm.
What are major differences between 60mm throttle body and original? Is it just with larger holes and accordingly fixing holes are in larger diameter or is there something else?
mukle is offline   Reply With Quote
Old 11-18-2012, 09:18 AM   #199
An IAT is now located. Unfortunately there is no good place in a front intake, so wires have to be extended. There is IAT re-location kit available or a Bosch socket costs 3€.
We reduced a flange height from 25mm to 20mm. Runners are now 34mm long.
A question for Trask users. Is there more than 20mm clearance between a Trask plenum barrel's rear corner and an airbox cover?
The idea, you can cut runners from our flange and fit complete Trask plenum straight on it.
Old 11-18-2012, 10:42 AM   #200
The rear hose connecting the charge pipe to the plenum rubs the under side of the air box. so raising the plenum 3/4 of an inch could be problematic, this is why I suggested make a throttle body with your fixes.
Old 11-19-2012, 11:43 PM   #201
Bruce Helland
Greg you will just have to change your airbox cover so you can use this. Either that or go the direction Doug is planning.
Bruce Helland is offline   Reply With Quote
Old 11-20-2012, 12:18 AM   #202
why does the IAT have to be in the flow path of the entrance to the throttle body wouldnt it be better in the plenum somewhere?
Old 11-20-2012, 10:24 AM   #203
Karzza is using individual runners and wants his flange to be as universal for everyone as possible. You do want it near the throttle body to give the most accurate reading. Good question, thats why we like the posts on this thread. If you use Karzzas setup, you can go from a plenum to IR, add intercooler, ram air, water injection, etc by using silicon connectors.
Old 11-20-2012, 02:45 PM   #204
Exactly, it is not relevant to measure a hardware or sun shine temp as a IAT-value.
This i s more important when a forced induction, because IAT variates a lot more and quicker than in case of a normally aspirate.
In the best case IAT-measuring is included to MAP-sender.
Old 11-24-2012, 07:24 PM   #205
Karzza are you building a prototype or has this project stalled?
Old 11-25-2012, 11:52 AM   #206
No, it has not stopped.
The aluminum bar will be machined to 9pcs of the plenum flanges at 8th of December.
Mukle and Kazza have some other, the plenum case related, parts in a design prosess
Old 11-27-2012, 08:56 AM   #207
goneracin1234
karzza- did kms calibrate that sensor for you to fit the v-rod or is it a plug and play, i didn't see a chart on there website with the range for it.
Old 11-27-2012, 10:40 AM   #208
I got the temp-resistance values from KMS. The strongly logaritmic scale is very near of a stock IAT's.
Old 11-27-2012, 11:19 AM   #209
goneracin1234
Thats what i was wondering if its not close check engine light will be on. This is what i was going to use but still waiting to hear back from them with the values. How much are they? I want to try one in the supercharger kit.
Old 11-27-2012, 01:00 PM   #210
That's the answer I got from KMS while I sent V-Rod stock IAT curve to them.
"Our sensor has similar resistance.
Official it is NTC +/- 2,2 kOhm at 20-25degree"
