Oil Dipstick with Cold Oil? - 1130cc.com: The #1 Harley Davidson V-Rod Forum
Old 11-23-2012, 07:08 PM   #1
woverby
Woverby
woverby's Avatar
Is there an oil dip stick that is accurate when the bike is cold, and on its side stand? Seems like the dipstick could have a mark to measure the cold oil level on a side stand, and another for hot and level? Sometimes it would be convenient for a quick check of the oil before heading out from the garage in the morning. The cold line could actually be a multiple set of lines, for a range of "cold", non-operating temperatures?
<Doesn't always play well with others....>
2009-AW with Rinehart 2:1 & Ceramic Coated Pipes
Detachable Windshield & Saddle Bags for Touring
Engine Guards with Highway Pegs
Sundowner Seat
Forearms
AutoTune
PC-V
woverby is offline   Reply With Quote
Old 11-23-2012, 07:27 PM   #2
The next time you change your oil, after adding 5 quarts of oil, let it set for a bit then, with a cold engine and the bike setting on its jiffy stand, mark a spot on the dip stick where the oil level is at. Problem solved.
Old 11-23-2012, 07:37 PM   #3
That's the game plan for me as well.
Old 11-23-2012, 07:38 PM   #4
That's the game plan for me as well. Or in my case 4.732 liters.
Old 11-23-2012, 07:39 PM   #5
woverby
Woverby
woverby's Avatar
Yes, agreed. I was giving some thought about the best way to make the mark, probably a hacksaw blade. That said, I wonder why this isn't part of the stock dip stick, or offered on an after market one. I have had other vehicles (possibly one bike), where there were hot and cold oil level marks. Automatc transmission dip sticks often have this.
Sundowner Seat
Forearms
AutoTune
PC-V
Old 11-23-2012, 08:49 PM   #6
I would use a small file with a sharp edge. Hacksaw seems a bit brutal. You don't need a real large mark.
Old 11-23-2012, 09:34 PM   #7
I think you are overintellectualizing this whole thing. Every other motor vehicle I have I can read the dipstick, or oil sight guage, hot or cold and the reading is seldom different. Why are you all fussing about this bike? The difference in hot and cold oil levels certainly isn't enough to effect a decision to add half a quart or not. Yeah, the oil level is a touch higher when hot than cold, but when the bike is dead cold you know all the oil is in the pan and not still dribbling it's way down from the heads. Do you really think it makes a difference whether you read the oil level hot of cold?
Old 11-23-2012, 10:05 PM   #8
langwilliams
don't you need to start the motor first to fill the filter then let the oil drain down an check it?
langwilliams is offline   Reply With Quote
Old 11-24-2012, 06:19 AM   #9
Tassie Tony
Devils Advocate
Tassie Tony's Avatar
With the bike on the sidestand the oil level is about 1/2'' above full.Look on the back of the dipstick closely there are small marks there that match the level.Use those.
Tassie Tony is offline   Reply With Quote
Old 11-24-2012, 03:24 PM   #10
Out of curiousity I checked and yes, there are two divets on the plastic that match up to cold check on the stand. Transfered this dimension over to my temp dipstick unit and marked it.
Old 11-24-2012, 09:39 PM   #11
woverby
Woverby
woverby's Avatar
Did my pre-winter oil change and cleaning today. I did not have any cold oil level marks on my stock dip stick. There was a small indentation about in the correct place, but looked more like a manufacturing defect. No visble manufactuing marks on my 2009 stock dip stick to check the cold oil level.
Sundowner Seat
Forearms
AutoTune
PC-V
Old 11-25-2012, 08:08 PM   #12
Yes
Old 11-26-2012, 08:25 AM   #13
Yes, those small molding divets are what we are talking about.
Old 11-26-2012, 08:38 AM   #14
Feedback Score: 14 reviews
The problem with checking the bike on the side stand is that the side stand bushings will wear and change the amount of lean the bike exhibits on the stand, which will change the oil level reading, so it won't be consistent over time. It ain't that hard to sit on it and level it up to check the oil.
Old 11-28-2012, 07:47 PM   #15
Lason
Lason's Avatar
I marked my dipstick after the first oil change and on mine cold on the kickstand, oil level is right in between the A and R on "warm" so I got a set of wire cutters and put a notch in the dipstick at that point. The dots on my dipstick were not anywhere near that point btw. I'm pretty sure those dots are from the molding process.
Sent from my Nexus 7 using Motorcycle.com Free App
2013 Night Rod Special
-ABS/Security
-DDM Tuning HID
-Customled tail light flasher module
-Memphis Shades Bullet Fairing
-Dynojet Power Vision
-Vance and Hines Comp 2-1
-K&N air filter
Lason is offline   Reply With Quote
