Broken Butterfly Shaft - 1130cc.com: The #1 Harley Davidson V-Rod Forum
Old 11-21-2012, 05:39 PM   #1
Demthios
To boost or not??
Demthios's Avatar
Images: 19
Well, finally took the 1350 up to the dyno this weekend to figure out what gains I'd gotten over last winter..ya ya I know it's damn near this winter but was just having to much fun with it during the summer to take it up to them. Well everything went okay on the ride up, after they got done with warm ups they guys came to give me the results. 132hp an 90lbs not bad but not what I was expecting but then they tell me the bike is idling weird and that I should replace my twin tech with the Race tuner.
I gladly declined but wondered with what they mean that the bike was idling weird. On the way home the first stop like the bike wouldn't come down from 2k thought that was weird, second stop light the bike wouldn't come down from 3.3k....hmm, 4th stop light same as the third and I made it home. To really pissed at the dealer to think straight I just put the bike away. Well today I go out to figure out whats wrong since it hit 70 here today, and wanted to go for a ride. I pull the air filter off and start checking stuff and I notice the the back half of the rear cylinder butterfly shaft is missing.
My heart sinks thinking that it went in the engine, so I tear off the airbox pull the TB's and sure as shit it's gone. Split right at the screw, thinking all crap I break out the flash light and look down the intake, both valves are open and I can't see any damage, so I stuff some towels down it and look around in the valley of the engine and fine the missing half. Oh thank you god!
Here are some pics of the shaft and the dyno sheet.
ID:	191503   Click image for larger version
Name:	2012-11-21 15.58.53.jpg
Old 11-21-2012, 07:05 PM   #2
bproulxvrod
bproulxvrod's Avatar
Images: 12
Feedback Score: 36 reviews
Is that one of Scott's where he welds the screws on now?
2002 V-rod: Yellow w/yellow ghost flames (frame painted to match)
2003 100th Anniversary VRSCA bagger edition
bproulxvrod is offline   Reply With Quote
Old 11-21-2012, 07:30 PM   #3
Demthios
To boost or not??
Demthios's Avatar
Images: 19
I believe it is one of Scott's, but I bought it from a third party on here. So not sure if it is one of the newer design one or not.
Old 11-21-2012, 07:56 PM   #4
pgilliam1
pgilliam1's Avatar
So is the shaft that broke a stock Harley part or are your throttle bodies non-stock and aftermarket? You got real lucky that your engine didn't eat that part.
Old 11-21-2012, 09:12 PM   #5
No chance of eating that. It's on the outside of the tb.
Old 11-21-2012, 10:40 PM   #6
Jeck
Fade to Black
Jeck's Avatar
Feedback Score: 15 reviews
Scott is an expert at fixing them, and winter is here. I had the same problem years ago.
Jeck is offline   Reply With Quote
Old 11-22-2012, 08:02 AM   #7
Ok so it was a 53mm bored to 58mm with the bolts welded? If that's the case, at least the screw remained in place so welding it worked!!! That's why I had the shaft upgrade by Scott in my last engine work, tried to bulletproof as much as possible at once.
Old 11-22-2012, 10:11 AM   #8
Sorry to hear this Kris.
You are lucky for sure.
That could of caused some serious damage.
I am sure Scott will get you back on the road soon.
Good Luck on the next one
Old 11-22-2012, 10:52 AM   #9
Demthios
To boost or not??
Demthios's Avatar
Images: 19
Thanks Rod, yeah I'll send it off to Scott and have him fix it up. Need to smooth out the bore now as well since it scratched it up pretty bad.
Old 11-22-2012, 08:20 PM   #10
sburke91
'04 1300
sburke91's Avatar
Is Scott still making the model with the redesigned shafts?
Sean Burke--Delaware OH
'04 VSRCA
1300 'Baby Destroyer' Stroker
SE Heads, Jones Cams/Valves/Springs
Destroyer TB and Injectors
CP Pistons
Bub 7 2-1
Delphi/SERT, sometimes TSII for tuning
Lots of other bits and pieces
Coming someday (if I ever get around to plumbing it):
sburke91 is offline   Reply With Quote
Old 11-23-2012, 09:12 AM   #11
ohioVROD
Senior Member
ohioVROD's Avatar
Images: 107
Feedback Score: 31 reviews
Yes we make two types of 58mm throttle bodies.
1) Bore out stock unit re-install stock shafts and add half shafts on top of the butterfly blades, insert new screws, and then tig weld them into place.
2) Bore out stock unit install (2) new stainless steel shafts and add half shafts to the blades, insert new screws, and then tig weld them into place.
Option 1) is a 50/50 on whether or not the original shafts dont break. They always break where the tapped hole is in the shaft. Ultimately the shaft is too small but making a bigger one is not a option at this time seeing you would have to re-engineer the entire setup.
Option 2) is rock solid as of right now but nothing is guaranteed in the high performance sector. Welding the screws is the best bet to insure nothing falls down into the motor. Unfortunately this option is pricey each shaft is hand made by one of our skilled precision toolmakers.
D.A. FITZGERALD CO., INC. / FITZGERALD MOTORSPORTS Your one stop performance VRod shop!
Authorized dealer for Vance & Hines, MegaCycle Cams, CP Pistons, Brown's Plating, Carrilo Rods, ARP Studs, Falicon Crankshafts and Diamond Heads.
Services offered: Case Boring-26T Pulley-58mm Throttle Body-Slotting Sprockets-Pinning of Bearings-Custom Machined Wheels & Rear Pulleys- Engine Brace Kit
Contact us at
ohioVROD is offline   Reply With Quote
Old 11-23-2012, 10:29 AM   #12
Demthios
To boost or not??
Demthios's Avatar
Images: 19
Scott,
Wanna shoot me a PM on what the cost of option two would be? Hopefully not as bad as normal since it's already bored out and everything lol but gotta do what you gotta do.
Old 11-23-2012, 11:20 AM   #13
I have to ask. Why not make the shafts out of 4130 or a more fatigue resitant steel, even stainless? As for the bushings, wouldn't Turcite or delrin be a better choice to tame the chatter noises?
Old 11-23-2012, 03:12 PM   #14
Scott,
Does this thing have a warranty?
Old 11-23-2012, 03:51 PM   #15
