1487cc Turbo 2nd Edition - Page 15 - 1130cc.com: The #1 Harley Davidson V-Rod Forum
Old 09-14-2012, 10:29 AM   #211
Finally I got parts for the next modification, 8deg raked "trike" triple trees and a Pingel steering damper.
The parts have to be finished and chromed, so most probably I'm not able to test drive the mod before the next summer. The season starts to be over here.
Old 09-16-2012, 08:24 AM   #212
Originally Posted by sburke91 View Post
How much does your baffle drop the sound level? It's still pretty straight-through.
You were right, a noice meter says 109dB at 4100rpm.
edit: I noticed afterwards that silencer wool has disappeared during the season.
Old 09-22-2012, 12:39 PM   #213
A poor weather biking season is over here, my saldo less than 2000 km Usually I'm doing >5000 km.
We had the last local cruising night yesterday.
I ran out of fuel, but was not so unlycky than another bike guy...
http://youtu.be/cNSoKU1DT6Y
http://orp.kuvat.fi/kuvat/2012/Vanta...ing+21.9.2012/
It will be the first winter for a while without an engine rebuilt.
Just a triple tree project is going on. I can find out something else to do than V-Rod.
See you later
Old 11-12-2012, 03:09 PM   #214
I was decided to be happy with the setup I have, but
....when we are making a new flange and plenum....
A high end of GT2560R compressor looks so much better than GT2554R in 1487cc, I just can't live w/o testing it.
This seems to be an endless story.
A pre-work of compressor housing's chroming is the most unpleasant job I know.
Old 11-12-2012, 03:17 PM   #215
VrodPete
Elephant Motors Rock
VrodPete's Avatar
Bigger blower, bigger boom.
'08 VRSCAW
1402 Oilman Elephant Motor - Fitzgerald Motorsports Style
(Fourteen-Oh-Twous Copicaticus)
HD SE II Cams, 3/8" Falicon Crank, Carillo Rods, CP Pistons, DA Fitz Engine Brace, Destroyer Injectors, Doherty oil pan, DA Fitz Head Port/Polish/+1mm Valves+springs, DA Fitz 58mm TBs, ARP studs, V&H 2nd Gear+Shift Shaft, Motohouligan Airbox, Wegner 2->1 Exhaust with Supertrapp V5
152.77 HP, 101.06 TQ
Other Toys: '01 BMW K1200LT, '76 Honda CB550F, '81 Mooney M20J
VrodPete is offline   Reply With Quote
Old 11-12-2012, 03:25 PM   #216
And more frequent rebuilds...
Old 11-12-2012, 03:37 PM   #217
1 bar = a fun
2 bar = the parties
Old 11-12-2012, 03:42 PM   #218
LOL! Darn it Karzza, you're indeed a party ANIMAL!!!
Old 11-13-2012, 06:52 AM   #219
VrodPete
VrodPete's Avatar
Originally Posted by Karzza View Post
1 bar = a fun
2 bar = the parties
Jeez, I'm breaking the tire loose all the time with 150HP, what's your last name, Michelin?
'08 VRSCAW
Old 11-17-2012, 02:02 PM   #220
Did order, no return:
- GT2560R inconell (to 330hp crank)
- a pile of silicon hoses
- a stack of aluminium tubes and curves
- the flanges will be machined in Dec by member Mukle
The Show Must go on.
Old 11-17-2012, 02:08 PM   #221
Good luck with the build.
Old 11-17-2012, 02:29 PM   #222
Exclamation
Meanwhile, in Finland...
Old 11-18-2012, 02:07 AM   #223
mukle
Oh my God Karzza. It looks like St. Anger of boost took this round.
Yes. If everything goes well we will machine flanges in 8th Dec. Unfortunately this was first free weekend to us. But this gives us still some time to check and double check flange design so it is suitable for all purposes.
mukle is offline   Reply With Quote
Old 11-18-2012, 08:38 AM   #224
sburke91
'04 1300
sburke91's Avatar
I'm having flashbacks of the carnage when the motor in BadRod II let go.
Sean Burke--Delaware OH
'04 VSRCA
1300 'Baby Destroyer' Stroker
SE Heads, Jones Cams/Valves/Springs
Destroyer TB and Injectors
CP Pistons
Bub 7 2-1
Delphi/SERT, sometimes TSII for tuning
Lots of other bits and pieces
Coming someday (if I ever get around to plumbing it):
sburke91 is offline   Reply With Quote
Old 11-18-2012, 10:45 AM   #225
is the GT2560R a direct bolt on or will you make to make changes for clearance?
