cam advise please - Page 2 - 1130cc.com: The #1 Harley Davidson V-Rod Forum
Old 10-15-2012, 08:59 PM   #16
The Broker
The Broker's Avatar
Thanks guys will keep my head spinning just looking for enough track horse power!
Sent from my iPad using MO Free
The Broker is offline   Reply With Quote
Old 10-18-2012, 07:43 PM   #17
vrunner79
vrunner79's Avatar
Your gonna have pleanty of Track HP on paper my tune was 128hp and the first time on the track with my "F" my best time of the day was 11.35 @119.85 mph
2009 VRSCF
vrunner79 is offline   Reply With Quote
Old 11-05-2012, 09:57 AM   #18
5aint
5aint's Avatar
Originally Posted by VrodPete View Post
I can say it's very streetable at 150HP, but that took a 1402 motor and SE II cams. If you are talking about a NA motor you'd be getting on the short side of reliable in that range (IMHO). You'll either be going to bigger pistons or an even longer stroke, and both have seen some reliability issues. Now if you turbo it with a mild engine upgrade (and def. NOT SE II cams!) you might see it and have it be reliable. Rod (Member RSC) is the turbo king around here. Lane (Member Lane) can tell you each and every one of a turbo'd bikes limits
So basically what I got out of all this is if I intend on a supercharger, do not supercharge with stage 2 cams. Why is that? That doesn't seem like its pushing the engine too much. What about 58mm throttle bodies? Are they ok to run with a supercharger? I'm pretty much done cosmetically with the bike so now it's time to soup it up.
maybe i need to approach my question this way. what can i do performance wise with a supercharger? headwork? stage II cams? 58mm throttle bodies? 26t pulley? are there other options ( i dont mean a turbo or big bore)?
Sent from my iPhone using Motorcycle.com App
Current: Kreater carbon kit, BSTs w/ ceramic wheel bearing, Swan composite rotors, K&N Topless, Bub 7 2-1, Daytona Twin Tec, Progressive 440's, MS Biketec upper fork covers, Arlen Ness Deep Cut grips and pegs (powder coated), Arlen Ness RAD III mirrors, HD reduced reach handlebars, Figure custom derby and clutch cover, HD Black LED headlamp, Porsche horn cover.
Ordered:
Planned:Holy-Moto SC, Bitchin Seat
For Sale:PC V (08 retro fit), Sundowner seat
Go big or go home
5aint is offline   Reply With Quote
Old 11-05-2012, 10:56 AM   #19
Louis
Posting From The Pub
Louis's Avatar
Assuming the original cam is competent (and it does seem to be) all another one can do is move the power around the rev range. Presumably you have a Road Rod for sports touring, and all the aftermarket cams are designed to move the power up the rev range (which of course means more of it). So... Why do you want another cam?
I haven't got them, but the Harley stage II cams seem very competent. You'll get more top end performance at the expense of the midrange. If that's what you want.
Louis
2007 VRSC-AW (Fun).
Old 11-05-2012, 03:33 PM   #20
rc4man
EXCELSIOR
rc4man's Avatar
Supercharger, ie. forced induction, basically negates the need for more radical cams and larger TB's.
The reason for those mods is to put more charge into the cyclinder which a SC or TC do naturally.
Typically for an otherwise stock engine a good SC or TC install provides some of the most HP with the least additional wear of engine components than radical cams, and an engine that doesn't run finicky at low RPM's
Old 11-07-2012, 09:30 AM   #21
VrodPete
Elephant Motors Rock
VrodPete's Avatar
^^ Here's your explanation. The SE II CAMS have a long duration and a lot of overlap - so with forced induction you're going to essentially just push more of your charge right out the exhaust before you compress it. Take a look at some of what Jan-Dirk has done, using only stock cams. With cam timing and some creativity you can build a great top end for an FI motor with no more than stock cams.
EDIT: I'd also add that (IMHO!) a big bore motor puts more charge into the cylinder "Naturally", there's nothing at all natural about a blower !
'08 VRSCAW
1402 Oilman Elephant Motor - Fitzgerald Motorsports Style
(Fourteen-Oh-Twous Copicaticus)
HD SE II Cams, 3/8" Falicon Crank, Carillo Rods, CP Pistons, DA Fitz Engine Brace, Destroyer Injectors, Doherty oil pan, DA Fitz Head Port/Polish/+1mm Valves+springs, DA Fitz 58mm TBs, ARP studs, V&H 2nd Gear+Shift Shaft, Motohouligan Airbox, Wegner 2->1 Exhaust with Supertrapp V5
152.77 HP, 101.06 TQ
Other Toys: '01 BMW K1200LT, '76 Honda CB550F, '81 Mooney M20J
VrodPete is offline   Reply With Quote
Old 11-07-2012, 09:46 AM   #22
Boost
Back in Black
Boost's Avatar
Images: 35
Feedback Score: 12 reviews
also most people are running turbo not supercharger. There is a difference, do some research on supercharger before you spend the $.
My bikes mods (lucky enough to have 2 v-rods)
My bikes pictures
Founder of NightMare's NightRiders!
Boost is offline   Reply With Quote
Old 11-07-2012, 10:23 AM   #23
rc4man
EXCELSIOR
rc4man's Avatar
SC's and TC's are compressors and by the "nature" of their operation they compact more a higher pressure charge into a given space
Personally love and believe in Turbo's. Had T'bird Turbo coupe in 80's and turbo diesel truck now. Simple reasonably trouble free devices which give alot of additional performance without excess strain on valve train components.
Haven't felt the need to add one to my Rod, but my Mazda 3 on the other hand, hmmmmm..........
