Holy shift light Batman! - Page 3 - 1130cc.com: The #1 Harley Davidson V-Rod Forum
Old 10-03-2012, 08:04 PM   #31
Stovetop535
Thanks for the pic. I put a call into the dealer but "guy I needed to talk to" was already gone for the day. Maybe tomorrow I will be able to get ahold of them.
I ended up just running it off the rear coil. I used the yellow/blue wire and the light works perfectly. I even re did the connection to the ecm before I tried the coil wire. The rear coil is very easy to get to and for my application, gives a much better reading.
So the light is up and running and I am happy. Thanks for troubleshooting and bouncing ideas around with me.
I did get ahold of Raptor today. He said he did not know what they would be using that pin for, but he said he would look into it. I told him no big deal, as by then I had wired it into the coil and I will most likely leave it there.
Stovetop535 is offline   Reply With Quote
Old 10-03-2012, 09:35 PM   #32
vrunner79
vrunner79's Avatar
Glad you got it working Let us know what you find out about the #3. Post a photo of your light
2009 VRSCF
vrunner79 is offline   Reply With Quote
Old 10-03-2012, 09:40 PM   #33
Stovetop535
I will get some pics up of it tomorrow. I can tell you this much I absolutely love it though. So much better than trying to see the factory one. You sure won't miss the automated one when it lights up. It is very bright.
If anyone is looking to order one, check eBay. I picked mine up for about $125 shipped.
Sent from my iPod touch using MO Free
Old 10-04-2012, 11:23 PM   #34
Stovetop535
Some pics of the light.
And one last pic of it, since I cleaned it today.
Old 10-05-2012, 07:37 AM   #35
vrunner79
vrunner79's Avatar
Very nice I have the same light BUT I had a Aluminum bracket made since the Autometer one had a big crack going through it, plus a new bracket moved it lower to the cluster. Ill get a photo of it up
2009 VRSCF
Old 10-05-2012, 10:50 AM   #36
Stovetop535
Yeah it would be nice to have it mounted a little closer to the cluster. my only complaint with the setup would be the mount. It seems pretty cheap. I do think it looks better painted black, bit that doesn't take away from the fact that it's still a plastic mount.
Old 10-05-2012, 01:00 PM   #37
vrunner79
vrunner79's Avatar
Heres the solution to the plastic mount. And its set lower
If I get a few requests for them I could get them made at a lower price
Sent from my DROID RAZR using Motorcycle.com Free App
2009 VRSCF
Old 10-22-2012, 11:13 PM   #38
Questions:
1) If I wire the shift light to the same wires that go to the tach, it's supposed to work right?
2) did any of you guys had to program the light to make it work?
Old 10-23-2012, 07:37 AM   #39
vrunner79
vrunner79's Avatar
Originally Posted by FABSTER View Post
Questions:
Good question actually. I would think if you tapped into the wire going right to the tach I would think so, otherwise the #3 PIN on the ECM..OR.. The Negative wire on the coil of your choice.
2 - I believe the Autometer light I had to set to 1.5 pulse setting, i'll have to look in the instructions again but each light usually has a base setting for what your needs are
2009 VRSCF
Old 11-07-2012, 08:25 AM   #40
DanSola
Good stuff! Thanks vrunner for the picture and guide on how you install your shift light from autometer.
DanSola is offline   Reply With Quote
Old 11-08-2012, 12:55 PM   #41
vrunner79
vrunner79's Avatar
Thank you If I can do it I think anyone can do it if you have basic automotive knowlage. I was intimidated when I tried it, lets face it your going into the ECM which basically controls everything and your worried your gonna make a BIG mistake. Every shift light I ever seen is the same, 3 wires Red,Black,Green . so the only wire you need to "wory" about is the green wire. Switch hot Red and Ground Black. As always, read the instructions and either dissconect your battery or pull the main fuse when doing any kind of electrical work, in the Service manual it has you cutting off power for any work you do. Anyone else adding a shift light, post up photos of your work
2009 VRSCF
