ECM failure? - 1130cc.com: The #1 Harley Davidson V-Rod Forum
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > V-ROD Discussions > V-ROD EFI
Old 11-05-2012, 12:59 PM   #1
josephthreedogs
reservation dogs
josephthreedogs's Avatar
ECM failure?
I was loading a map into my '06 Dyna using a SERT, about 90% complete and my laptop said I had lost communications with the ECM. Trouble codes were downloaded and I had two, U1016 and U1255. What went wrong and is it repairable or will I need a new ECM and of course a new tuner? I have loader many maps in the past and have never had a problem, did I screw up or did my ECM just fail.
josephthreedogs is offline   Reply With Quote
Old 11-05-2012, 01:57 PM   #2
I'm not sure. I found a similar problem reported in this thread.
The OP ended up having to get a new ECM but this was for an '08 VRSC. You may be able to try sending the recalibration again after checking your SERT cables and connections or you may need to have a dealer reflash the ECM.
Old 11-05-2012, 07:45 PM   #3
pwrman
Registered Idiot
pwrman's Avatar
Did the power dip at all? Battery fully charged? Any cables kinked or have weak connectors?
pwrman is offline   Reply With Quote
Old 11-06-2012, 04:08 AM   #4
Jan-Dirk
Autobanmod
Jan-Dirk's Avatar
Images: 361
Normally your ECM shouldn't be toast.
Charge or replace the battery and repeat the upload and it should be ok.
Worst case you have to take it to a HD dealer to have the ECM restored with the scanalyzer.
Hog of Steel
Jan-Dirk is offline   Reply With Quote
Old 11-06-2012, 04:52 AM   #5
schwingding
schwingding's Avatar
Did you retry it? Very occasionally my bike will fail to complete a download. It always takes it on the following attempt. No reason that I can tell. I'd shut everything off, power it all back on and retry.
I know they're VERY sensitive to power and I always leave the charger on while I'm doing this. Don't know if it helps but it can't hurt?
schwingding is offline   Reply With Quote
Old 11-06-2012, 06:10 AM   #6
To reduce drain on the battery during an ECM recalibration I always pull the LIGHTS fuse before turning on the ignition.
Old 11-06-2012, 08:00 AM   #7
capngeo
George
capngeo's Avatar
Images: 163
Feedback Score: 10 reviews
J3D.... If you need it for troubleshooting, I have an ECM which has a bad fan circuit. Everything else works except the fans. I saved it just for ruling out a bad ecm. If you need it, just pay shipping both ways.
Prices on
are Negotiable!
____________________________________________
The World's ONLY "
" V-Rod
Ol' Bubba, Popes of Hell MC
You start the game of life with a full pot o' luck and an empty pot o' experience...
The object is to fill the pot of experience before you empty the pot of luck
capngeo is offline   Reply With Quote
Old 11-06-2012, 09:16 AM   #8
josephthreedogs
reservation dogs
Tried it again using all the above hints, keep getting a message on the laptop saying bad ECM or OS failure have ECM repaired by your dealer.
Old 11-06-2012, 07:00 PM   #9
pwrman
Registered Idiot
pwrman's Avatar
Check for bent or pushed in pins in the connectors. Disconnect the battery for a few and reboot.
Old 11-07-2012, 02:25 AM   #10
Jan-Dirk
Autobanmod
Jan-Dirk's Avatar
Images: 361
can you readout the VIN, is the SERT communicating with the ECM?
Hog of Steel
Old 11-07-2012, 09:29 AM   #11
josephthreedogs
reservation dogs
Yep i can get connected to the bike, it reads the vin, part number and map I tried to load but I keep getting a message that my ECM needs to be taken to the dealer for repair. It loaded about 90% on the first try and now will only load 3% before I get a failure notice.
Old 11-07-2012, 09:54 AM   #12
Jan-Dirk
Autobanmod
Jan-Dirk's Avatar
Images: 361
that's not good, take it to the stealer then
Hog of Steel
Old 11-07-2012, 01:40 PM   #13
josephthreedogs
reservation dogs
I have a new ECM and pro tuner in stock, soon as I get my aircleaner and injectors I will be takeing it to the dealer for help.
Old 11-07-2012, 06:28 PM   #14
That happened to me once and it was some sort of USB port miscomunication apparently, it scared the shite out of me... Have you done any upgrades to your computer or software that may have chaged the way the SERT comunicates?
