Multiple DTC's Engine won't fire. - 1130cc.com: The #1 Harley Davidson V-Rod Forum
Old 05-01-2012, 08:36 PM   #1
031130
Location: Milwaukee/Lake Lac Vieux Desert (U.P. border, snowbelt)
So i finally wrapped up the PITA valve lash on my 03 all valves were within spec (25K miles). Get the bike outside and it's cranking away and no go-bike won't start. When i turn the ignition on and flip the switch to "run" on the handle bars the fans immediately come on and that ain't right. I get the following codes
>P0107 = MAP sensor open/low
>P0113 = IAT (makes sense as i was checking codes with airbox cover removed)
>P0118 = Engine coolant circuit...?
>P1351 = Front coil driver open/low
>P1354 = Front coil driver high/ shorted
Damn. I took my time and did everything as per the manual advises. The bike always ran great and i have never had any problems ever...until now. Anyone have any suggestions. Thanks guys.
Warped rotors. Dunlop tires-180 rear. Syn3. Dogs Ass intact.
031130 is offline   Reply With Quote
Old 05-01-2012, 08:53 PM   #2
capngeo
George
capngeo's Avatar
Images: 163
Feedback Score: 10 reviews
Start with your grounds!
Prices on
are Negotiable!
____________________________________________
The World's ONLY "
" V-Rod
Ol' Bubba, Popes of Hell MC
You start the game of life with a full pot o' luck and an empty pot o' experience...
The object is to fill the pot of experience before you empty the pot of luck
capngeo is offline   Reply With Quote
Old 05-01-2012, 09:15 PM   #3
gator582
Retired, Not SLOW!
gator582's Avatar
Question
Originally Posted by 031130 View Post
... When i turn the ignition on and flip the switch to "run" on the handle bars the fans immediately come on and that ain't right. ...
Didn't we hear something like this recently and it was a non-OEM battery with the terminals reversed and the cables connected to the wrong terminals?
DIRE HIS NIKS!!!
“You don't need luck in life, just sex and money.” - Tom Coronel @ Dakar 2016
gator582 is offline   Reply With Quote
Old 05-01-2012, 09:57 PM   #4
031130
Could you please elaborate as to what grounds i would be looking at. I know role eyes. This just chaps my azz after what a pita it was to do valve lash. Everything went back on the bike the way it came off. I now know why techs wish to not work on "our bikes".
And yeah replaced the battery last year with a non HD brand and it ran great.
Personally i think vavle lash should be done at 30K miles. I have yet to hear of a V that blew up because... "well if he just would have checked valve lash this never would have happened...etc"
Old 05-01-2012, 10:06 PM   #5
HoneyB
Pat (Patrick!)
HoneyB's Avatar
Images: 14
Feedback Score: 31 reviews
There are ground connections on the top of each Head, and from the rear of the Engine, to the Frame. (And to the Battery, of course.)
'04 VRSCB, SERF, Amsoil air filter & oil, Drilled Exhaust, Arlen Ness Mirrors, relocated Signals, Sundowner seat,
Tiger Racing belt guards, Pondo's pivot bolt covers & 'V' valve stem caps, Tyson's black riser and foot levers, Metzler ME 880's, black 5 spoke '08D wheels and rear pulley, Mini LED rear signals, Progressive suspension, Jeannie Guardian Bell!(so far!)
1978 Honda XL350 (w/4300 miles on it!)
Jedi:"It's free to be a member, but it'll cost your ass in the end..."
HoneyB is offline   Reply With Quote
Old 05-02-2012, 06:14 AM   #6
...cranking away and no go-bike won't start. When i turn the ignition on and flip the switch to "run" on the handle bars the fans immediately come on and that ain't right. I get the following codes
>P0107 = MAP sensor open/low = not connected
>P0113 = IAT sensor open/high = not connected
>P0118 = ECT sensor open/high = not connected
>P1351 = Front coil driver open/low = not connected
>P1354 = Rear ignition coil open/low = not connected
Your symptoms indicate that the main engine harness is disconnected. It could be a bad ground but then I would expect other DTCs.
The symptom of a reversed battery connection is turn signal bulbs on with ignition off.
Old 05-02-2012, 06:22 AM   #7
I thought the same thing Steve when I saw the post.
Check your connections on the left side by the TB's
Now that the lash is done. I have a Question.
Did you pull the motor or leave it in the bike?
Old 05-02-2012, 08:19 AM   #8
031130
Thanks for the tips i'll double check my grounds and all connections to the various sensors. RSC lash was checked with the engine in the frame.
Old 05-02-2012, 10:09 AM   #9
031130
Another lesson in humility. The connector by the TB thats orange on the inside was not completely seated. I'll get back at it. I'm guessing i'm good to go.
Old 05-02-2012, 03:22 PM   #10
031130
All good and back on the rode. Thanks guys for leading me in the right direction, i knew it was something minor. Might be hitting up rsc for some head work and cams next winter But i'm
Old 05-02-2012, 03:25 PM   #11
gator582
Retired, Not SLOW!
gator582's Avatar
DIRE HIS NIKS!!!
Old 05-03-2012, 11:52 AM   #12
07 HD V-Rod
H-D StepChild
07 HD V-Rod's Avatar
Lightbulb We got answers
I LOVE this forum!
07 HD V-Rod is offline   Reply With Quote
Old 05-04-2012, 11:05 PM   #13
031130
Originally Posted by 07 HD V-Rod View Post
I LOVE this forum!
You and me both man. I have to say that people I have dealt with on this forum are the best. The only other vehicle i have riden/driven that pulled at my heart strings like my VRod does and i had an instant emotional attachement to was a 03' F1 360 Modena. Think maintaining a VRod is a pain...
