Anyone swap the 2012 DX wheel yet? - 1130cc.com: The #1 Harley Davidson V-Rod Forum
Old 04-11-2012, 10:29 AM   #1
Firemt27
As the title says, has anyone swapped the 2012 new spoked DX wheels yet onto an older model DX? I'm trying to make up my mind on these. A big selling point over the Muscle wheels is they are cheaper and already are powdercoated black which will save me more money in the long run.
2007 DX Vivid
K&N (topless) - PCIII
Avon grips/Joker concealed bar ends
Tons of black p/c'ed parts
CD/MBW fork signals
Progressive front lowering springs w/ stock HD oil
ProComp boots - Buckeye's Fork tube covers
DDM 55w 6000k Hi/lo h4
Avon Cobra's w/ 250 rear & Dynabeads
Dogs ass removed-Heavycyles stage 2 non-v
Bub 7 2-1 exhaust
Aw pass seat - HD mini sissy for the wife
Arnotts
Firemt27 is offline   Reply With Quote
Old 04-11-2012, 11:09 AM   #2
Demthios
To boost or not??
Demthios's Avatar
Images: 19
Cpt America did a great write up of switching over to the muscle wheels. There are a couple different ways you can go about doing it but need to decided on if you want to use your stock axles or swap out for the new ones. I plan on putting the 2012 DX wheels on my 05B here shortly, just waiting for them to ship out. I'm going to use the method the Cpt America did on his and just get some of the spacers machined and made.
Old 04-12-2012, 06:12 AM   #3
Astronut
Astro
Astronut's Avatar
Agree
Yeah, I would have to agree that CptAmerica did a fantastic job on his Wheel mod...
Astronut is offline   Reply With Quote
Old 04-12-2012, 08:05 AM   #4
TheWolfman
The Big Bad Wolf
TheWolfman's Avatar
Feedback Score: 13 reviews
I'm going to do this to my '10 DX instead of replacing the crushed stock wheel. If I remember right, CPTAmerica had to do the axle conversion because his 'Rod was older than '08, am I right? Aren't the '08 and later models compatible with most of their parts? Shouldn't I be able to do a straight one-for-one swap or does the inverted forks make it a new beast requiring a conversion?
RIP, Kevin. The Original "Black Widder", 1964-2012
Forget your lust for the rich man's gold. All that you need is in your soul. Thanks, Ronnie.
TheWolfman is offline   Reply With Quote
Old 04-12-2012, 08:19 AM   #5
bronsondant1
Toxic Avenger
bronsondant1's Avatar
Images: 8
I have the 2012 DX wheels on order. I should have them on my 08 DX by the end of the month. I'll post pics when it's done.
"Once you go black..."
[SIGPIC][/SIGPIC]
Topless '08 VRSCDXA
PC III
Toxic V-Lux
HD LED Headlight
Killer Glass
Arnott Air Suspension
HD Black Diamond grips and pegs
Custom C&C seat
GR240 Rear Fender
Metz 280
(PA/MD/DE/VA/DC)
bronsondant1 is offline   Reply With Quote
Old 04-12-2012, 08:38 AM   #6
Badwolf
Just completed
I HAVE JUST COMPLETED THE SWITCH ON AN 08 SIMPLE JOB JUST NEEDED TO MACHINE THE REAR SPACER AND SHIMS TO CENTER THE WHEEL AND INSTALLED THE DOUBLE ROLLER BEARINGS IN BACK. FRONT IS SIMPLE SWAPOUT LOOK IN BADWOLF'S GARAGE BIZ'S CUSTOM
Badwolf is offline   Reply With Quote
Old 04-12-2012, 08:42 AM   #7
Demthios
To boost or not??
Demthios's Avatar
Images: 19
Yes, 2008+ bikes have a 25mm axle where the 2007 and lowers have the 1" axle. So for you guys that have the 08 bikes it is just a straight swap out for the newer 12 rims. But for me and Firemt27 we will either have to swap the whole rear end or cut down a new axle or go the route Cpt America did and swap out the bearings and fab up some spacers to fit it.
As for the front wheel, won't make a difference at all if the forks are inverted or not. Still using the same axle size and all so should be just fine.
Old 04-12-2012, 09:00 AM   #8
bronsondant1
Toxic Avenger
Images: 8
Ok, now I'm confused. BadWolf is saying there is some fab involved to get the 2012 DX wheels on a 2008 DX. Demthios is saying it's a straight up swap....Which is it?
[SIGPIC][/SIGPIC]
Topless '08 VRSCDXA
PC III
Toxic V-Lux
HD LED Headlight
Killer Glass
Custom C&C seat
GR240 Rear Fender
Metz 280
(PA/MD/DE/VA/DC)
Old 04-12-2012, 09:53 AM   #9
Badwolf
Just the centering of the wheel with the bushings in the swingarm and the bearing spacer inside the wheel needs to be cut for correct bearing spacing and then if i remember the cush drive to the pulley spacer needed to be adjusted i think it was about .040 0ff that spacer using the double roller bearings
Old 04-12-2012, 09:58 AM   #10
Firemt27
Yeah, Capt America did an excellent job and write up. When and if I do the swap, I'll be referencing his thread. I love the muscle wheels but price wise I was looking at the 12' Dx wheels. I was just fishing around to see if anyone had actually done it on their 2011 and under dx so I could get a visual idea of how they would look. Im assuming the 12' Dx wheels are the same size (ie: bearings, axles, etc) as the muscle wheels. I planned on cross referencing the wheel installation kits for both to confirm or deny my theory.
08+ is a straight swap for the muscle to dx wheels. 07' and under requires the write up of CPt America. Assuming the 12' dx wheels are the same size of the muscle wheels it should also be a straight swap.
2007 DX Vivid
CD/MBW fork signals
Bub 7 2-1 exhaust
Arnotts
Old 04-12-2012, 10:46 AM   #11
bronsondant1
Toxic Avenger
Images: 8
Contradictory statements I think. Muscle to DX wheels? I have an 08 DX and I want to put on 12 DX wheels. I need to know exactly. I don't have the facilities to do the work myself so I am having the dealership do it while they are replacing my bad ABS sensors. If there are some "gotcha's I want to make sure they are aware before they do it.
[SIGPIC][/SIGPIC]
Topless '08 VRSCDXA
PC III
Toxic V-Lux
HD LED Headlight
Killer Glass
Custom C&C seat
GR240 Rear Fender
Metz 280
(PA/MD/DE/VA/DC)
Old 04-12-2012, 10:49 AM   #12
Badwolf
different animal with the abs brakes can't tell you what it would be haven't done it on the abs I know there is somthing with the bearings that differ too!
Old 04-12-2012, 10:51 AM   #13
Badwolf
you can go to ronnies.com and look at oem micro fich and see if there is a visual and part number differance to!
Old 04-12-2012, 11:08 AM   #14
Badwolf
go to the cpt. america's listing and follow his advise just went over it again and he is right on, I just opted to get the heavyer duty rear wheel bearings of the 07 and go from there,sorry if I caused any confusion but Cpt. is right on with his (http://www.1130cc.com/forums/showthread.php?t=160339)
Old 04-12-2012, 11:15 AM   #15
bronsondant1
Toxic Avenger
Images: 8
CptAmerica did F wheels on a DX. I'm doing 12 DX wheels on a 08 DX w/ABS. I'll just have to work with the shop to make sure it isn't screwed up. According to them it's a straight swap.
[SIGPIC][/SIGPIC]
Topless '08 VRSCDXA
PC III
Toxic V-Lux
HD LED Headlight
Killer Glass
Custom C&C seat
GR240 Rear Fender
Metz 280
(PA/MD/DE/VA/DC)
